Hi there, please can someone help me fathom out what's wrong with my heating:
The hot water works fine, and when the programmer commands the water to be heated, the boiler fires up, the pump starts running, the 2-way valve opens and everything is working OK.
However, the rads never get hot (any of them) when the heating is on at the same time as the hot water (my programmer has a 'twice per day' setting, which I usually use for both water and heating).
If I turn the hot water off (on the programmer), and the heating to 'continuous', then the 2-way valve motor opens and hot water obviously flows through the valve as the pipe downstream of the valve gets hot. If I move the room-stat then when I turn it to a low setting I can hear the valve-motor closing the valve, and when I turn the room-stat up I can hear the boiler firing up. However - in this condition (i.e. with the hot water turned off), the pump never starts operating and downstream pipe is very slow to heat up as if the hot water is just trickling through and not being pumped.
I'm a bit confused, as the pump works OK when the hot water is on, and the room-stat and heating valve seem to be operating. I just can't get the rads to heat up. I checked a few of the rads to see if there was air and there doesn't seem to be any, water came out of the bleed valves straight away.
Please does anybody have a suggestion? Thanks.
