I am trying to wet pressure test some central heating pipe work that will be fed from an unvented cylinder.
I understand 10 bar for 10 minutes is a suitable pressure for testing.
At 10 bar the pressure is mostly stable.
I have been experimenting at a higher pressure ie 15 bar, there is pressure loss ... no flexi's, can't see any leaks - so am curious why a slightly higher pressure should have such a different effect.
I have compression isolating valves on the ends of the pipes (4), to vent any air, and some compression fittings before the pump, am I right to think that only a slight weeping out of any of these will cause a noticable drop on the pressure dial.
I have been looking at push fit fittings to make the job quicker and easier, someone suggested a push fit stop end with a bike valve screwed into the end, sceptical that would be water tight though. Pulking olives and weeping fittings isn't ideal.
I also find releasing the pressure and re-pumping a few times helps to reduce the amount of loss ... would this indicate air in the pipes anywhere, I am sure their is none.
Any thoughts appreciated.
