CENTRAL HEATING PIPES LEAKING
5 Jan 2007
London
hello all,
what will be the signs if there is a water leakage somewhere in the pipe work on a central heating system, apart from the obvious wet floor that you might find.
the reason why i ask is if you have a pipe that is hidden in the walls and is leaking, what will be the signs?
will the boiler fire up at all.
Tie up the ball valve on the small tank and observe the water level.
If it keeps going down then you know there is a leak. :D
