Central Heating pipes location regulations
14 Jan 2003
I need to install 2 extra radiators and want to chase the pipes (plastic type) into the wall for one of them, using the plastic conduits(would have used the floor but there is a Gas pipe in the way). Are there any regulations about how pipes should be run? Can they run horizontally in the wall or diagonally across the floor?
I know for electric cabling this is not allowed and would like to know if there are similar regulations for central heating pipes. Note, I will make sure I have no joints in the wall or floor.
You can run your pipes either way.
Remember tho that if you create an inverted loop on the vertical plain, you will need air vents at the highest point. :D
I think other responses missed the point. A pipe in a wall is at-risk from getting drilled. Obviously avoid directions except verticals and right-angles. And make sure that attention is drawn somehow to any pipe in a wall running down to a radiator.
People are used to not drilling immediately above / below electrical fittings but they will NOT normally expect buried pipes.
Good advice from CC.
I personally don't believe in pipes in walls and certainly not in chases under concrete.
However, the customer is always right.......... :(
Thanks for the reply, I will have re-think as to where to run the pipes, and may end up running them just above the skirting board.
