central heating pipes
23 Sep 2016
can I paint ugly radiator pipes in radiator paint until I can get them boxed in.
Bog standard oil based eggshell or gloss will suffice.
I dont know if all rad paint is the same but I painted something other than rad/pipes with it and it remained sticky so guess it needs baking to go off properly.?
I for one have never bothered with the so called "Radiator Paint"
Using an oil based gloss [or Matt if preferred] I let the Rad and pipes go cold, prep and paint then leave to fully dry generally 24 hours then turn on the heating again.
I find that the colour is good with no discoloration and I find this sort of paint works fine.
Just wondering if the paint formulation is indeed all that different between "normal" oil based paint and the more expensive "Rad paint"?
Ken.
Isn’t it an enamel paint? (Whatever that actually means.)
