- Joined
- 4 Jan 2015
- Messages
- 13
- Reaction score
- 0
- Country
Hi.
I have a central heating system that I installed over 10 years ago. It consist of an Alpha Ocean Combi Boiler 4 double radiators, 1 towel radiator, 1 plinth heater and I later added HEP2O underfloor heating to the conservatory, all on the ground floor.
The main flow and return are 22mm copper and the radiators are teed off in 15mm copper.
The boiler pressure vessel failed a few years back and was replaced with a separate under-floor vessel at the manufacturer's recommendation.
This year on turning the central heating on for the Winter, one of the radiators and the underfloor heating are not getting hot. The underfloor heating is on the end of the line but the radiator is not and has one radiator in the line (which is working) between it and the underfloor supply.
I can bleed both the non-working components and there seems to be plenty of pressure. If I feel the flow and return to the underfloor, just before the shutoff valves, I can feel heat in the flow but not in the return. With the radiator there's no heat apparent in either the flow or return.
I checked the TRVs and they appear to be OK, so I'm begining to suspect a blockage. A few years back the system was losing pressure and as I couldn't locate the leak, I applied Fernox leak sealant and I wonder if that could have caused a blockage?
Also, If I drain down the faulty section and apply high pressure air from my workshop compressor, is this likely to cause any damage?
Any other suggestions?
Regards,
Alan.
Regards,
Alan.
