Hi , i have had a pressure leak on my central heating system , it became more noticeable recently with the cold weather , i tracked it down this evening to a valve in my boiler , a grant vortex pro external .
See video of leak
photo :
https://www.dropbox.com/s/g9bxrw7hlk23lh4/InkedPhoto 05-03-2018, 8 36 12 pm_LI.jpg?dl=0
It was leaking under the large nut ,,. see photo ( green arrow ) i managed to tighten it a bit and the leak seemed to stop , it looked like it had been leaking around the tap nut (red arrow ) so i tried to tighten it a bit . Bad idea it started spraying water out around the seal .
I got some towels out straight away and bled the pressure from the system .
i took the tap nut off and it was badly corroded around the sealing face , i was surprised not to see a copper sealing ring or something .
should i replace the valve or try to wire brush the sealing faces off and use some ptfe tape on the threads ?
any advice would be appreciated .
See video of leak
photo :
