Have Potterton Suprima 60 boiler, Landis RWB9 programmer, Myson CP53 pump and an acl/lifestyle 22m mid-position valve.
All was working OK until a few weeks ago.
Hot water is fine, but radiators are either cold or tepid. Pipe from valve to rads stays cool even when programmer is calling.
Plumber suggested valve assembly replacement as he thought the motor may have blown and it was awkward to get at. Quoted £247 + vat.
Declined this offer, and managed to replace motor(Synchron) myself. Still not working. Manual switch on side of valve has never worked (noticed today that it has sheared off), but assume that the motor should still open valve when called to.
I can open the valve by easing the spring back in the valve assembly, and the rads then heat up. Tested the motor by lifting it out of assembly - but it doesn't spin at all when CH is called from programmer.
Not sure what to look at next. Any ideas ?
