my central heating is a gravity fed condencing boiler.had been still for around 6 monthes. however ! up on restarting have found several problems of which i have cured most. there seems to be the large radiator down stairs thats still not getting hot, the feed pipe its hot but the return pipe is cold.rad only luke warm where as all others are very hot. have replaced the pump! replaced rad valves. checked 3 way actuator valve and re-cleaned that.flushed out rads still need to replace a gate valve to copper tank(hot water) would a power flush help . or is there another problem i have'nt spotted, has any one got any other ideas, unless your a plumber please dont make a comment. contact me at ****.****@ntlworld.com
