- Joined
- 30 Dec 2016
- Messages
- 4
- Reaction score
- 0
- Country
Hi everyone,
I have a few central heating issues at the moment.
Firstly the red Grunfos pump which is in the airing cupboard runs constantly. I used to turn the heating on when required and turn on the pump while the heating was on. When the heating was off I used to flick the 3 speed switch on the pump so it was between positions 3 and 2 so not running.
However last night the pump got really noisy and failed so today I bought a new Grunfos UPS2 which replaces my old UPS unit. However this has a digital three speed switch so you can't turn it off manually and it is running constantly now.
I also fitted a new Drayton Mid Position Actuator about 2 years ago.
Also my boiler often makes a buzzing sound, sometimes not too noisy and sometimes very noisy like a hornet in a cage. I think this might be down to failed smoothing capacitors?
I would like to get all the issues sorted but money is very tight and I just spent £110 today on the Grunfos pump.
1. Do I need a new circuit board in the boiler and will that fix the buzzing AND the pump running constantly?
2. Could I get the board repaired locally at an electronics specialist I know?
3. Should I get a specialist to sort it all out or am I safe to swap the circuit board myself?
The boiler is a "Gloworm Ultimate" which has been fitted since the house was new so coming up to 20 years old now.
Thank you in advance for any advice.
