- Joined
- 16 Jan 2004
- Messages
- 23
- Reaction score
- 0
- Country
Hi
Oilman very kindly helped me a few weeks ago with some suggestions for a noisy pump that I have. But I still have a problem, it does sound like there is air in the system, but I have no idea how it is getting in. I have one rad that gets air in it. I would normally expect a rad with air in it to be cold at the top and hot at the bottom, this is not so, it is cold on the right hand side from top to bottom and hot on the left hand side from top to bottom. I have made sure that the valve is fully open to ensure that the hot water can get in and for a few days after bleeding it the rad stays hot all over, then it starts to go cold again. If I leave it unchecked for 3 - 4 weeks then I get the scenario described above. In addition the pump is still making a gushing gurgling noise when the system first comes on, it also sounds like there is a tap running in there for the 1st five minutes when it comes on! All other rads are fine and don't need bleeding, I have bleed the pump and nothing came out of there except water. Although I did do this not long after the heating went off so maybe the air didn't get chance to collect there? I have also checked the feeder tank in the attic - this is covered so there was no debris in it, although the water was a slight murky colour, the tank was full and the ballcock is not stuck. Any suggestions as to how the air is getting in, as it must be getting in some where! As I have tried most things I wondered if it was a problem with the boiler? I have a corgi plumber who fitted the boiler 2 years ago & I have tried without success to get him to come in and service it. All other people I know are plumbers and not Corgi registered, so before I go to the expense off getting in some one new who I don't know - can any one give me some suggestions?!! Please, as another night of being woken up with the gurgling and tap running noise when the heating comes on is going to drive me mad!! OK essay over now!!
