Please bear with me - its my first post on my house and I'm not used to forums and no little about heating systems (i am a woman - is this an excuse)
I have gas central heating with a tank in the loft and a cylinder in the hot press and a boiler in the store downstairs. Hope that sorts out what type of system it is. The programmer is a sunvic select 207. It is about 10 years old i think. Till a few days ago it done what it is supposed to so, came on and off as set am and pm. Now it does not. It still works manually if i switch it on and off but the programmer/timed bit fails to work. When i switch it on/off manually the heating system/water works as it should. no other problems.
Am i correct that the programmer has given up the ghost? If so is all i have to do is buy a replacement and get someone to wire it in?
I noticed the the same model number is still on sale but looks different of course from my old one. Link to new one below.
http://www.discountedheating.co.uk/shop/acatalog/Sunvic_Select_207_XLS_2_Channel_Programmer.html
If as i think it is the problem do i just buy the above or should i leave the choice of purchase to the professional. Will the newer model work OK with my system (assumed it will the model number is the same as one on now)
Last question - who do i call to fit it - an electrician or plumber?
Thanks ever so much - im sure i have got it wrong but i have no one really to ask apart from calling a plumber. Just want a bit of direction or confirmation before i do that.
