my drayton lifestyle lp522 programmer has burnt out,can any one tell me what other programmers have the same back plate or similar to save me rewiring a new back plate.
regards johnsm
But check the wiring diagram to make sure before you install.
If it burnt out then there may be a short on external wiring which has overloaded the circuit board in the programmer. If this short is not cleared first you will fry the new one too.
BTW a customer of mine had a cat with a liking for chewing the wiring in his boiler room. Blew a fuse but not before frying the programmer and room stat. Cat went on to live another day and chew another cable!
