Central heating pump disaster
29 May 2007
Good evening everyone. I would be most grateful if anyone could help me with some problems.
About 12 years ago, I installed a closed loop oil fired central heating system and everything has worked OK over this period.
Unfortunately, about a week ago, the circulating pump shattered internally and blocked the flow of water through the system. The pressure relief valve opened and emptied the system.
I obtained a new Grundfos replacement pump and fitted it into the system. When I refilled the system, I found that the pressure relief valve was faulty - water was pouring out of the outlet.
Water was also seeping out of some of the 3/4 inch soldered joints on the copper pipe.
I replaced the effected copper soldered connections with compression fittings. I also replaced the
pressure relief valve. The original pressure relief valve had a male head which fitted into a female
socket on a T piece. The new valve has a female fitting. To fit the new valve I had to use a female to female adaptor.
My problem now is that I have leaks in the system which I am sure is due to incorrect sealing.
It is 12 years since I installed the system and I have forgotten a lot and I need some help.
How do I seal the female to female adaptor? - I have put Boss White on the threads but this seems to be ineffective.
I also have a leak where the pipework connects to the burner.
Any information would be most welcome
Many thanks
Jimmy
Hi Jimmy. The threaded connection is done with PTFE tape, fed onto the male thread in a clockwise direction.
We would need more details of any other problems.
Do you have a red expansion vessel??
If it's a thread you need to seal, PTFE tape is what you need.
Wind on clockwise when viewing from end of thread, like this -
@PullerGas
Many thanks. Yes. I have a red expansion tank.
I have read somewhere that using twine is more efficient on some of the connectors? What is your opinion?
@ Whitespirit66
Many thanks for your help. How many loops of PTFE tape should I use ?
@PullerGas
That's hemp - it's been banned for years because it can grow bacteria:rolleyes:
Expansion vessel connections are often needing that amount of PTFE.
If the oil pipe is weeping you'll need an oil approved sealant such as Rocol. If it is 10mm soft copper tube it should have been fitted with an insert where a compression olive is used, as the pipe is not strong enough to be considered fit for purpose without.
That being the case then clearly either the wrong thread standard is being used (such as parallel to taper or vice versa) or the manufacturer is not complying with standard dimensions (quality control - or lack of)
