Hi there,
I'm having an issue with my central heating which i cant seem to solve. Its an old Ideal WLX RS60 boiler with Sunvic timer, tank stat, room stat and 2x 2 port motorised valves.
I've only been in the property just under a year and both CH and HW have always worked without issues, however when the boiler first switches on there has always been a very loud waterfall noise. The problem has been evident the last few days where the pump will continue to run long after both CH and HW have been turned off. It appears to only happen when the CH has been switched off as each time the HW is turned off automaticly by the timer the pump will stop within a few minutes. Also when CH is switched off the radiators now cool down very quickly as i guess the pump is still cycling the water round the radiators. The boiler itself is off and never fires again once CH switched off, just the pump itself.
The pump itself appears to be only 2 years old though the rest of the heating system i'm guessing is orriginal and 25-30 years old. I've also now noticed a small leak on the pipes leading into and out of the pump but unsure how long this has been going on or if it has anything todo with the problem.
The pump itself and the pipes leading into and out of the pump remain red hot while the pump is still cycling even after the radiators themselves are cold. Manually opening the two motorised valves result in the waterfalling noise again and the boiler firing up so it appears neither are stuck open and as both CH and HW work fine they dont appear stuck closed either.
I've had to resort to switching off the system at the mains once the heating is off.
The boiler is in a bedroom wardrope which is always warm so dont think the frost stat is the problem and i'm unsure if the boiler has an overrun sensor or not but cant find any mention of it in the manual or part list.
The only thing i can think of is the CH valve is sticking partially open alowing enough water through to keep pump running but not enough to fire boiler but i dont understand how the water is remaining so hot going through the pump hours after the boiler last fired.
Appologies if any of this makes little sense as i know next to nothing about central heating systems other than what i've read trying to diagnose the problem.
Any help would be appreciated.
Neil
Neil
