I think i have a dodgy installed central heating pump.
I have done various different things and have found the following which i think shows the pump is in the wrong direction.
I drained the system and removed the pump, i used the isolation valves, but when i re filled the system with the pump still out only the bottom valve leaked (valve closest to the boiler). I checked the top isolation valve and it was open, but no water was coming out. So i know i have a dodgy isolation valve, and a very wet kitchen.
I guess this showed the pump was connected to the hot side of the boiler, and from what i've read so far should be pumping away from the boiler.
The old pump was connected so as to pump into the boiler, which i think was wrong.
