there is a long copper length of pipe apx 16" leading from the top of the pump which is next to the hot water tank, at the top there is a screw nut, after bleeding all the radiators, i undid the screw nut, and air escaped, when water started to spill out, i tightened the nut, can someone confirm that this is for bleeding the pump?, someone has told me there is supposed to be air inside this pipe, as it stops the pump from being noisey?
