Have a gravity fed system which has a faulty pump that needs replacing. Only done this a few times and the few times I have done it. I’ve managed to isolate the valves and change the pump. But the pump valves are passing in this one.
If I was to turn of the mains and find a drain off on a radiator (hopefully) and drain will that be enough then to disconnect the pump and replace ?
