please help me going mad!
I have a problem with central heating had a lot of crud in pipes that where causing blockages in system. I have taken every rad off and flushed each one and then flushed each pipe out and those that would not clear have been replaced. I have also replaced the air seperator that sits above the boiler (that had some crap in it to and also had a pin hole in it). I also flushed the heater tank inside the boiler and cleaned the thermostat. reset refilled the system and it is again getting hot but after some time it sounds like its blowing bubbles into the header tank in loft and sending boiling hot water to it. i'm running out of ideas could anyone please give me some advice as to what I do next????????
