My heatng (Yplan, micobore, G rated boiler, no room stat, TRVs on all rads) is down just now due to a radiator having just been swapped, an electrical fault and a service.
The electrician is coming nest week to repair the SAT> earth problems introduced by extending the cyl stat cable and the supply to accomodate the bathroom. The original installer used the E of the T&E for the SAT and te bathroom instllaer elc conected all the earths together.
I gave the system a good flush for a few days with renovator before shutdown.
There wasn't much sludge as the system is drained every year and was retreated just a few months ago after the draindown for the new bathroom. I;d like to keep it that way as can;t afford to have all the aads changed or replace the microbore.
Is there such a thing as a mechanical trap for sludge that could be fitted in line, eg with a magnet (same idea as in a transmission gearbox)? If so what models are reliable?.
While it's down, is it worth getting an automatic bypass valve fitted where the original installer put a manual valve.
It's a G rated boiler Ideal Stelrad W2000 RS40 and hoping to change in the next year or two, probably for some sort of Combi with a little storage (not sure yet), so don't want to take too much money away from the budget as there'll be additional work on the kitchen to accomodate new plumbing system.
