Hi all,
I hope you can offer me a little advice?
I have a Y-plan system I believe which uses a Honeywell 5-wire 3-port mid-position valve. The problem I have, happened 3-months ago I think and it has been driving me crazy ever since. It's not a serious problem (yet) but when I switch the programmer to constant with CH and HW on too, nothing seems to happen for several minutes, about 15-30 actually? There is no pump or boiler action in this period.
I do eventually get hot water and heating - it all seems to work fine after that, so it seems like a small problem really - Its just that, why the initial delay?
I'm electrically trained, but by no means a plumber, so I have large gaps in the theory of the design of my system, especially where the 3-port valve is concerned.
The HW seems to work as designed, so I'll put that to one side. So the problem is that when the system is just calling for CH, I get this initial start-up delay. I have checked the room stat and it seems to work ok in so much that when the heating is going, it switches the pump and boiler on and off just fine. Also, the boiler seems to be doing what is asked of it, so back to the valve I guess.
Whilst I was waiting for the heating to kick in today, I started to look at the valve. I have read on this site that the valve has a manual override, so I slide it to the right and it went 2/3 of the way. With some effort, I did manage to get it fully to the right, am I right in assuming that it should be very stiff and offer a lot of resistance, because mine does? I didn't help troubleshoot the problem though. However, I was expecting it to return to the 2/3 position at some point, but all evening I have been able to slide it easily from fully left to fully right - there is no resistance or spring tension as I have seen mentioned before?
The CH and HW "seems" to be working ok, but perhaps its too soon to tell what damage I may have done by forcing the manual override, but in summary: -
1. Can anyone help shed light on the mystery of the CH start up delay - for clarity sake, there is no call for HW at this time, due to the cylinder stat being set quite low deliberately to isolate the problem.
2. How does the manual lever work and what resistance should I feel when the system is in normal operation - i.e. powered?
3. Have I knacked the valve, should I feel some spring tension and should it be replaced?
Many thanks in advance for any advice
