Hi - I wonder if you can help.
I have a Baxi Bermuda Inset2 Boiler - about 3.5 years old.
Over the past couple of weeks I've noticed that my Central Heating is switching off before reaching the required temperature. When I switch it on at the control panel the boiler fires up as normal, however, after it's been on for 5-10 mins the boiler switches off again - regardless of the temperature setting on my room thermostat. It then stays off for around 20 mins and then fires back up - but only for another minute or so! This cycle continues but it never reaches the point of getting my radiators much more that slightly warm.
I've replaced the room thermostat but it didn't help.
The hot water side of things appears to be fine - I don't have any problems heating this to the required temperature.
Any thoughts.
Any thoughts.
