Hello... I've been searching this forum trying to get my head around my central heating system and I'm not really any the wiser. Would be grateful for any clarification - never knew there were so many systems out there.
Basically I've just moved home and can't figure out exactly what's wrong with my system. I have a Worcester 12 Ri conventional boiler, British Gas UP2 programmer, cold water tank and expansion tank in the loft, cylinder upstairs with stat, grundfos pump and sunvic valve, room stat downstairs.
I thought my system was gravity fed but from what I read on this site this is a common mistake to make and now I believe it is called Fully Pumped, and I'm guessing in a Y Plan (can anyone confirm?).
The problem I've got is with my programmer. When I select HW I get hot water but when I select CH, I get CH and HW. I removed the programmer from the wall and on the jumpers on the back it was set to independent (not linked) HW and CH, but the system was set to Gravity Fed, not Fully Pumped. I changed it to Fully Pumped, put it back on the wall and turned CH on but nothing happened.
Set it back to gravity fed, put CH on and as usual, CH AND HW came on.
On the back of the programmer is a wiring diagram:
Neutral
Live
1. HW Off
2. CH Off
3. HW On
4. CH On
On mine, ports 1 and 2 have no wiring going to them. Is this my problem, or could it be a dodgy 3 port valve?
Neutral
Live
1. HW Off
2. CH Off
3. HW On
4. CH On
