- Joined
- 14 Feb 2010
- Messages
- 10
- Reaction score
- 0
- Country
System:
I have a sealed s-plan system with boiler in loft, Grundfos 25-50 Pump + unvented cylinder in cupboard in top floor, 22mm pipework supplying 5 towel rails & about 13 traditional style rads all with TRVs.
Problem:
The system was heated with an underspec'd Worcester 18KW Ri, but this was recently changed to a 24KW Ri which was as much as the gas pipe could manage.
However since fitting this new boiler there is a very constant loud noise coming from the cupboard where the pump is ( but could also be pipework coming from boiler) once the heating has been on for about 5-6 hours.
The rads seem to heat up fine and there is only very little air at the bleed points. There is water at the pump asides a soft rushing bubbly sound on start up. So I dont think it is an air problem. Also, there seems to be no restrictions in terms of pump valves, iso valves etc...
any ideas what problem could be????
Problem:
