Central Heating System
17 Apr 2013
Invernesshire
Hello All,
I have an oil fired central heating system together with a coal fire with back boiler both going into a centralizer/neutralizer.
I disconnected the old water tank and fitted a new water tank heated by two electrical elements.
The problem! I have a water pump connected to a central heating pipe in the loft that is on 24hrs constantly. It comes on when I switch on the power to the Potterson oil central heating system.
The water pump has a thermostat which was connected to the old hot water tank. I put it on the central heating pipe going into the neutralizer thinking it would switch the water pump on and off. No good.
Any advice would be gratefully received.
The thermostat was there to measure the water temperature inside the tank. Why didn't you fit it to the new tank? Will cost you a fortune to heat the water via the element(s)
Thanks Armo74
The new water tank is totally isolated from the central heating system and it only provides hot water. I use the little thermostats on the 2 elements to switch them off when water temperature reaches a certain level.
Can I use the thermostat to turn off the central heating and the water pump? Or, do you have any ideas that could save me paying a fortune for this 24/7 water pump. Thanks
