Hi
I have asked several questions before about my oil heating but i am now thinking of taking the plunge and upgrading the system.
The current system is about 35 yrs+ with original boiler for the oil. The red burner on front of the boiler has been replaced by previous owners and is fairly new.
The last service I got done on the boiler the engineer said that the blades in the boiler are very worn and will not get replacement as the boiler is too old.
The system consists of open fire back boiler, water cylinder in hot press with cold water tank feed above it in loft.
Some of the rads are mircobore piping and some have obviously been added and are the standard plumbing used to rads.
I intend to do some work to add more space in house and will have approx about 35 rads once completed over time. I want to remain with oil and need some advice on the following:
1. What size of boiler KW would I need for my house?
2. Grant Votex apparently are very good boilers?
3. Can I take away the hot water cylinder and water tank in loft and replace with Megaflow system?
4. Will I have to replace the microbore plumbing or can these rads be replaced with new rads and standard plumbing just by connecting?
5. Can I have the heating system setup as a smart system controlled by smartphone?
6. Approx cost - ball park figure £10k?
any advice would be great.
