I've been having a closer look over our central heating system in our new (30 year old) house and it could do with being upgraded a bit - Just after a bit of advice as to what would be the best thing to do with it. Trying not to spend too much on it as other things are taking priority!!
The heating system works fine and is powered by a wall mounted gloworm boiler in the garage. The gloworm does look a little old though but works fine.
We then have a manual timer on the wall in the garage which lets us have "timed", "off" and "constant". We don't have any way of selecting hot water or heating we just get both together.
There is also no thermostat anywhere - there is imply just a dial on the boiler which you turn from min to max depending on how hot you want the radiators/water.
So currently I've tried turning off all the radiators (except one which has seized) but it's a bit of a pain to do that and then have to open them again.
What I would like to have done is a Y-Valve put in and an electronic 2 channel timer to replace the old timer. Then probably thermostatic valves on every radiator and leave the boiler alone for the minute with a few of just having it swapped for a direct replacement in the future.
Does this sound possible and is it the best way to go?
