C
cjbigboy
Hi
We have Oil Fired central heating/rads with TRV's
After the heating has been on for a while we get a vibrating and the system has to be switched off.
The boiler is set at it's lowest point.
These houses were built in 2000 and my neighbour said it is caused by high water pressure and that I should turn it down. We do also get cold water pipes banging after the kitchen cold is run or when washing machine fills and the downstairs cold taps are silly pressure
Looking at our outdoor stopcock, there is a plastic on/off switch and then a plastic hex headed section anyone familar with this type of stopcock?
And can the pressure be adjusted if indeed this is the cause.
I have searched the forum and seen water hammer etc, but don't really know if this applies.
Sadly I know nothing about plumbing.
Any advice would be greatly appreciated
thanks
CJ
thanks
CJ
