Central Heating warm even though it is off
19 May 2006
Just moved into a new property and still getting to grips with the Worcester gas boiler/hot water system. The heating is off and the water is set to continously on. I have noticed that even thought the heating is off some of the radiators feel warm. I have turned the controls on the heaters to the 0 off position and this stopped the problem except for one heater in the living room which even though it is on the off position with the heating turned off still feels warm.
What could be the problem here? As I say, the heating is definately switched off. Is it to do with the hot water being set to continous?
It sounds as if there is a fault with your boiler/heating system. As you have not given details I cannot guess whats wrong there.
Also the radiator that will not turn off presumably has a faulty valve.
Tony
Do you know if its a Combi boiler, or a system boiler, with tanks in the loft and a large copper tank somewhere !
More info needed, like model of boiler ect.
