Hi all
I'm feeling a bit silly...
- I've drained the central heating (sealed system heated by combi boiler), and cut the 22m flow and return pipes ready to put a new radiator loop in.
-I want to run the flow an extra metre or 2 under the floor to give it a bit of warmth (I suppose you could call it informal underfloor heating!) but...
-I forgot to check and mark which was flow and which was return before I cut the pipes.
oops
Is there a way I can tell? (without installing temporary stops on the pipe tee's I've cut - refilling the entire system, bleeding, turning heating on, marking the pipes, letting it cool, re-emptying, taking off temporary stops)
For example - do the thermostatic valves on the radiators tend to be installed on the flow side?
thanks for your help
in slight embarrassment...
Stephen
oops
Stephen
