I have just moved a downstairs radiator and allowed the system to drain down through the disconnected pipes. Unfortunately I didn't know you had to switch off the boiler first! I have refilled the system and bled all the rads but when I switch on the boiler I dont get hot water to the cylinder or the rads.
I think its an air lock in the pump. Is it OK to bleed the pump while it is running and is it normal for it to take nearly an hour? Could the problem be somewhere other than the pump? What problems have I given myself for not switching off the boiler before draining down?
Boiler is an Ideal non-combi and pump is a Wilo Gold 50.
