I was just wondering if anyone knew the cause of this issue and whether it's a straight forward fix please?
I have a Worcester Greenstar condensing boiler (2013 model) with the hot water tank in the airing cupboard; and a Hive (Gen 1) thermostat - I inherited this set up when I moved in the summer and haven't bothered turning on the boiler until now.
What happens is I turn the boiler and Hive receiver on and then set the thermostat to 20 degrees. But when 20 degrees hits the Hive receiver says the heating is now off but the radiators just keep pumping the heat out full pelt until I turn the boiler off.
Also if I turn the boiler off but leave the receiver on, when I turn the boiler on again it starts the central heating again. I have to turn off both boiler and receiver for the boiler to 'reset'.
I've had a look on Google and it's suggested this happens when the central heating valve gets stuck? However, I'm not sure where/what the valve is. There is a small lever on the blue box (pic below) on the side out of sight nearest the wall - it appears to be stuck in 1 position. If this is the cause am I okay to try and force it to move?
I also have this device installed. I have no idea what it does but it was on a manual setting, which I changed to auto.
Any help is greatly appreciated.
