I seem to have constant problems with the Y-valve on the central heating
I replaced the head last year which improved things but we still had some issues.
Then I've forgotten about it all year as we haven't had the heating on, now we're back to colder weather we have started to use the heating and we are having problems!
The other day I put the heating on for an hour, all worked perfectly well the radiators heated up nicely and the house became warm - then when bath time came we realised the water was scalding hot even though it hadn't been on since earlier (before the heating was on).
Tonight I put the heating on (the water was already on for heating at this time) but half an hour later the radiators were still cold. Pulling the lever on the side of the valve has made the radiators start to w?arm up but it doesn't seem right.
Any ideas what I should check?
It's a conventional system. The boiler is only a couple of years old, the y-valve is about 6 years old although the head was replaced last year.
I think the valve is a danfoss valve.
