Central heating
13 Oct 2007
My central heating is not working. The radiators are fine, and the boiler is heating the water correctly. Any ideas ? I think maybe the pump has stuck. If so, how would I correct this ? Any ideas much appreciated as my other half is moaning !
thanks
Neil
I think you just give the pump a good whack but you might want to wait for someone more knowledgeable to come along.
Bleed the pump by taking the screw out of the middle until water escapes.
Put a small screwdriver in to check it is turning. :D
The radiators are fine and the boiler is heating the water.
So whats the problem :rolleyes: :rolleyes:
Normally the boiler will shut down if the pump isn't working.
I would guess an motorized valve has stuck.
Boiler make/model, type of system etc would be handy
