Hi, can anybody help? I have had a new boiler fitted before xmas and am having problems. The manufacturer says the boiler is ok and the installer says I have a leak somewhere.
The boiler is an alpha he33 and is connected to a unvented cylinder along with a pressure vessel.
I have since discovered that the combination boiler is the wrong type but the installer has said that he is only using the CH side! Waste of money i know but I just want the problem fixed.
The problem is that every morning the pressure in the boiler is at zero and as such no CH comes on. There is water being discharged through the blow off pipe but I dont know where it is coming from. The alpha tech disconnected the boiler blow off so it must be coming from the cylinder.
I cannot find a leak and the installer doesnt want to know....
If anybody can confirm whether or not a combination boiler is compatable with this type of set up I would appreciate it.
