Central Heating
13 Sep 2012
Wiltshire
Hi,I have a radiator in the kids room that is on a wall that is not under the window.I want to move the radiator over to the wall under the window but i don't want to start ripping up floorboards so could the flow and return pipes go up into the loft across the loft insulation then down again in the corner of the room to the radiator? Thankyou
what type of boiler do you have
2 tanks in the roof cold water and the overflow for the heating,hot water tank in the airing cupboard
If the joists are in your favour. It will just be a matter of lifting the floorboard near the radiator that will probably come up easy
then using plastic pipe you should be able to run it right to the other side of the room. It's the easiest way.
