I have a Vaillant 240 VCW XH Combination Boiler and it is 12 years old.
I have replaced the Main CH Heat Exchanger and the Diaphram including the Diverter.
The problem is when the CH is on and DHW is drawn at the same time.
Once DHW Tap is closed then the boiler shuts down including the pilot light. The pilot light is then re-lite and CH fires up as normal.
Can anyone please advise me. (Kev-plumb where are you, Sir).
Thank you very much for replying. If there is a problem with scaling where would it be in the boiler?, as I have cleaned/flushed out the Main Heat Exchanger, Diverter and DHW exchanger.
