Hello people, my first post so I hope somebody can help me!
I had a stiff tap in my bathroom basin. The hot side (not that it makes a difference) - and so I decided to undo the headgear nut and take out the valve from the body of the tap.
The tap is a lever turn, and has no washer, it is the ceramic-disc type (although the discs look plastic not ceramic)!!! - It is a pegler.
Anyway, after cleaning, I re-assembled the tap but noticed even when the tap was turned fully OFF, hot water still came through (not much but more than a dribble).
I re-aligned the discs and this continued to happen-then the little rubbery/nylon? washer/ring that goes into the bottom of the valve after the discs, I pushed that in tightly and finally the tap stopped dribbling!
Anyway, bascially is this normal? or do I have cheap crappy taps?!! As if the cold gets stiff, and I do the same, I hope I don't have the same problem! ... Has anyone else came across this problem before with these type of taps?
Lastly, as the headgear was stiff, very stiff in fact, I needed leverage on it to undo it from the tap body. So I disconnected the tap from the supply, by undoing the tap connector and backnut. All was good, but when I put it back, a slight dribble was coming from the tap connector. I turned the nut another 1/2 turn, until it was proper tight and it stopped. Will this be OK now ? I didn't put a new fibre washer or jointing compound (which I know is a good idea, as I didn't have any in the house) on the tap connector, to create a new, good seal...!
Thanks for reading, will respect your advice and look forward to reading them.
