- Joined
- 18 Mar 2017
- Messages
- 3
- Reaction score
- 0
- Country
Updated
Today I heard my hob making two pop sounds and later it smelled a little bad. I saw that my fuse went down. I have now turned the fuse on but the the power indicator of the hob is still not working. Should I call an electrician to fix the fault or purchase a new hob with installation.
The make of the hob is Diplomat and the model is APL 1324 (white). It is an electric hob built into my kitchen. I am not sure about the age of the appliance but I have it since 2008. I would assume it falls into those 10-12 years brackets.
As I heard the pop, I ran to the kitchen and smelled some burning. I immediately switched off all the Power points in my kitchen. I did see that there was little water from a boiling pan on the surface. I quickly wiped it. It is important to mention that this water was not any abnormal amount. Infact it was the usual spill from the lid. I would say 5-6 drops of water towards the bottom right side of the hob.
I later switched the tripped fuse back. Everything else in the kitchen is working except the hob. The indicator of the switch of the hob is also not lighting up. I am not sure if it is my hob or the Power switch. I am happy to get the repairs done. But would hate to pay unnecessary call out. I also know my hob is an old one and would be willing to get a new one if required. But I am not sure, whom to call - An electrician or hob installation. Could somebody please advise.
