Diversity is used to come up with a reasonable estimate of the total load for an entire installation. It is, clearly, also implicitly assumed with socket circuits as soon as you get more than 3 outlets.socks1 said:what about the "diversity guidelines?"
I thought you didn't just add the max rating of each appliance together???
Make that a separate ring, then that'll do nicely for the kitchen ring.socks1 said:ok this is what i am trying to do - i am converting my integral garage to a kitchen and the garage is already on the ring main.
I understand, but you shouldn't compromise a design because you want to avoid work in moving/routing cables.I am trying to avoid moving the 32A rated cable from the existing kitchen across to the garage/new kitchen.
I very much doubt it. Oven, yes, but hobs have to supply a certain amount of energy into the pans you're heating or they just won't work well enough, and that amount is considerably more than 3kW - that's typically about the power of one of the large rings...I thought if you could buy a separate ceramic hob and oven that were rated low enough you could get away with wiring then to the existing ring main.
