Ceramic hob tripping out
29 Jun 2009
Gloucestershire
Hi All,
can anyone help me. I was doing some cookong over the weekend when the lid on our pressure cooker came off and cover teh ceramic hob. Once I cleaned up I realised the whole house had tripped out.
I tried to turn it back on on the main fuse board but it would not let me. I then switched off the 45A switch for the hob (it is seperate from the oven) and the mains was ok. I let the hob cool down and tried to turn the switch back on only for it to trip the house out again.
Does anyone have any ideas what could be the cause of this? Could it be the switch blown?? I am thinking of replacing the switch first (the cheaper option) then if that does not sort it fix/replace the hob.
Oh it is a ceramic hob with built in overspill protection - don't know if this makes a difference.
Rich.
Sounds like you have one RCD protecting the entire house (which is not a recommended configuration now because of the exact situation you're seeing...)
I suspect some liquid from your pressure cooker has got in to the wiring for the ceramic hob, so when you turn the power on to the hob, there is a (probably very small) amount of conductivity between live and earth, which means the RCD trips. If you feel comfortable doing it, then you could try and access the hobs wiring (if its above an oven it might require taking the oven out etc), and look for any obvious dampness and dry it out - alternatively you could get an electrician in to do it...
Don't get those problems with gas hobs.
Even if the igniters start to cause electrical problems there are always matches.
There should be seals to stop spills getting into the wiring.
Chances are its run down the spindle of the control, it should dry out eventually.
Ive had ceramic hobs for over 25 years never cracked 1 yet, Scratched it though.
Leave it a few days and try again.
The switch is not broken, and replacing it will be a waste of time
