I am trying to source a new ceramic cartridge for my kitchen mixer tap. I have looked all over on line but cannot find one that matches mine. There seem to be so many different types.
I have a photo of mine here (which is a 40mm diameter):
Can't view the picture full size. You'll need to post a picture of the whole tap unless you get lucky and a member happens to be familiar with whatever brand it is.
Adjust your profile settings. Add some better pics.
Is the tap branded. If yes, contact manufacturer for spares.
If it's a budget, unbranded tap, and/or Chinese made, then sometimes it's near impossible to find spares. Binning it and starting it again would be your only option.
I have water leaking from between the lever (part 1) and the fixing collar (part 2). I conclude this is down to a failed cartridge and replacing it will solve the problem. Can anyone experienced in these matters confirm either way if my conclusion is correct.
