Certificated and Non certificated crushed concrete???
5 Jul 2010
Can anybody please tell me what the difference is between the certificated and non certificated crushed concrete?
I need some for a gravel driveway I am doing on my home, and the MOT type 1 certificated stuff is £38 per ton plus vat, where as the non certificated stuff is only £11 per ton plus vat.
I am only graveling a driveway.
Appreciate any info.
Purely a guess, but the certificated is exactly what it says on the tin whereas the non-cert'd can have all sorts of foreign bodies in it.
(That's in it not innit)
(I hope this doesn't start an anti-immigration sub-thread)
Thanks for the reply.
I understand what you are saying, but does that mean it is no good for a sub base?
I'm only a DIY'er but I wouldn't use the non-cert'd stuff for a sub-base 'cos there's a chance it'll have bio-degradeable stuff in, which will do just that and over time you'll end up with voids under the surface.
Another guess is that a Building Inspector would not pass it either.
But it's just my guesswork. I've never used it so I have no experience of how much 'contamination' there would be.
Incidentally, I think that MOT type 2 is OK and a bit cheaper than MOT type 1.
See this:
//www.diynot.com/forums/viewtopic.php?t=127643
If the non cert'd stuff is type 2, then it's probably OK to use, but the price would make me very wary.
I have 2x companies local to me offering the following:
company 1-
Type 1 crushed concrete £15 per ton +Vat
Company 2-
Non certificated crushed concrete £11 per ton +Vat
75mm to dust.
Aside from the fact that company 2 has 75mm (quite big for my driveway?) to dust, any reason why one is any better than the other? (aside from the price)
How come there's a £23 discrepancy from your first post to your most recent?
Perhaps this explains it better:
http://aggregain.wrap.org.uk/terminology/type_1.html
Reproduced:
Type 1
A specification for granular materials used as sub-base, as defined by the Specification for Highway Works, clause 803. Type 1 materials include crushed rock, crushed slag, crushed concrete and well-burnt, non-plastic shale - but sand and gravels are excluded.
Type 2
A specification for granular material used as sub-base, as defined by the Specification for Highway Works clause 804. Type 2 materials include crushed rock, crushed slag, crushed concrete, well-burnt non-plastic shale, and natural sand and gravels.
I think I've seen somewhere that Type 1 is more or less guarranteed to have no voids with 40mm particles down to dust, Type 2 probably no voids with 70mm particles down to dust and Type 3 up to 30% voids are possible.
I would ask your suppliers if they state that their product is MOT Type 1/2.
I think I've also misread your intentions. Are you thinking of using this as the finished surface? If so, I would think again. It should be used as a sub layer, compacted, and in the case of gravel as a finished surface, separated with a permeable material.
But I would repeat, I'm no expert. It's just my opinion.
Wisdom suggests that if you are laying any concrete then steer away from 'contaminated' products, particularly if using within a dwelling.
Problems can arise when using infill that has the potential to release harmful gasses. Sulphate gas can destroy cement based products particularly in damp conditions.
MOT type 1 is an inert and stable hard core infill that is suitable for most applications.
Use crushed concrete or whatever. I don't think it will make a difference.
I would be a little nervous though if there was a lot of broken tarmac within the infill! :eek:
i am concerned about the difference between what you are all talking about.. type 1 is a natural sub base... i.e. stone. crushed concrete does have no compatibility with type 1. or with the lesser aggregates.
