- Joined
- 4 Oct 2015
- Messages
- 2
- Reaction score
- 0
- Country
I have French patio doors that I am attempting to remove the CES lock cylinder. I have the key but am unable to get the mechanism to turn down to line up so that I can remove it. I have read and watched everything possible and removing the screw on the side of the door and turning the key 25 degrees doesn't do it. I am needing to do this because my lever on the door no longer springs back and want to see what has broken in the mechanism, but I can't get it out to look at it unless the lock cylinder is removed. I have tried everything that I know to get it to turn. I can see it moving inside when the door locks and when it unlocks. It needs to turn about 90 more degrees to line up so it will slide out. There is a little vertical slit on the front of my cylinder that I figure has to be the key to getting it out but I don't have anything to slip in there. Not sure what to do from here. Any help would be appreciated.
