I have one of these in my Garden. There is only one rectangular manhole cover with a large diameter pipe (you could climb down it) leading to an even bigger chamber at the bottom. It looks like one of them Large onion shaped things you see on the back of lorries on the motorway. It was put into the ground around 1994 if that's any help. There are no other manhole/ drain covers nearby.
Is this a cesspit or a septic tank? Most descriptions of a septic tank suggest a second chamber of some sorts which also has an above ground access chamber.
Thanks in advance.
Thanks in advance.
