Although I have used halogen lights to spot light some book shelves in a study, I'm looking for a lighting solution for my bedroom.
Currently we have three R50 bulbs in cental uplighter in a 3m by 4.5m room. This is useless, although the dimmer is used alot.
I have been in several hotels rooms that seem to be lighting a similar environment with either halogen or CFL downlights that are 5cm in diameter.
So I have been reading many posts in the forum, regarding downlighters and I agree that they are really only used for spotlighting. I'm interested in how I get achieve a even lighting solution in this room.
My starting point would be four CFL based downlighters using external control gear (?electric ballast?) as I need the use of a dimmer.
Are there any flat CFL's that are approx. 8cm in diameter and would that light my room appropriately. I was thinking something like this:
http://www.megamanuk.com/pdfs/fozz/cronos.pdf
Finally, since I would like a dimmer, I understand that I need to match this to the rating of the lights used, are there any dimmers like these to work with lower wattage CFL's?
http://sparksdirect.wordpress.com/2...-questions-about-dimmers-and-dimming-systems/
http://www.wickes.co.uk/Screwless-Flat-Plate-Electronic-Dimmer/invt/204935?source=123_4
Does anyone have a suggestion about where I can buy the required hardware as I'm a bit lost and all I can seem to find are recessed downlighters for double turn CFL's.
Thanks in advance
Thanks in advance
