- Joined
- 4 Apr 2022
- Messages
- 3
- Reaction score
- 0
- Country
Apologies if this is an already answered question, I did check the Wiki and the FAQ, but nothing quite lines up.
We've got an oil fired boiler (an ancient Camray 5) that has an integrated 12 litre hot water tank for DHW. The original system only had a Summer / Winter switch on it, no controls beyond that. But an optional timer was fitted to our one.
The part that's puzzling me is when the CH is running, and the hot water is set to "off", the DHW tank heats up as well. From what I can see in the diagrams in the manual, that should never be the case.
We did have to replace the actuator on the 3 way valve, as we were getting hot water but no heating at one point, but that appears to be working as intended now.
I guess what I'm unclear on is, is that expected behaviour on an oil-fired boiler with an integrated water tank, that having the CH on would also heat the DHW tank? Or is the 3-way valve not quite doing what it should i.e. going to CH only with no heating of the DHW.
With oil at the price it is, I don't really want to heat the DHW tank every time the CH is on...
