CH Balancing question
5 Jan 2017
I want to balance my nan's heating system, as there are a couple of radiators which do not get very hot. I have bled all radiators and no air has come out. I have read various guides on balancing which tell you to work out from the closest rad to the boiler to the one furthest away. The pump is actually upstairs in the airing cupboard, however the boiler is in the downstairs toilet. Do I need to work out from the pump, or the boiler? I guess I need to work from the pump in this instance but as I haven't done this before, I would appreciate if someone more experienced could confirm (or not) that this is the case. Many thanks.
Hi morgz84 and welcome to the forum.
You will find what you want in the FAQ's here.
The closest generally refers to the one closest to the pump (assuming the pump is on the flow and most are). By closest it means with regard to the pipe feeding it, not the radiator physically closest to it. For example there may be a radiator in the room directly below the pump, but the pipe feeding it may travel the length of the first floor before descending downstairs and back to the radiator. So in terms of physical location it maybe the closest to the pump, but in regards to the pipe length actually one of the furthest away. So, with regard to pipe lengths, the radiator closest to the pump will also be the one closest to the boiler.
A quicker way might be to just turn down the lock shield on the hottest rads.
Many times you will find that they are all fully open.
Most settings will be open just one full turn or even less.
I would suggest you check the setting on the hottest one first and see where that is.
Tony
Many thanks for your quick and helpful replies! I think I'll look at doing it at the weekend as the weather will be more mild. She'll go mad if I turn the heating off when it's below zero! :D She's got a little halogen heater she can use if necessary. My nan (bless 'er) is a typical 90+ year old. She'd like every radiator to be searing hot and boiler running flat out all the time with no thermostat!
You don't need to be turning off the heating while you do the balancing!
