I've got a Ravenheat RSF 820/20 combi boiler. Recently, on turning the hot water taps on the water often remains cold. Listening to the boiler it sounds as if the burner is only coming on when the tap(s) are turned on full, and even then it is intermittent (previously the burner had fired and the DHW had run hot even on small tap openings). However, if the burner is already on due to the CH, the DHW runs hot even at small tap openings ?
For info the pressure is (and always has been) set at ~1.5 bar, the temp gauge reads 60 degrees, the DWH thermostat is set high and CH thermostat at mid-range. The water pressure out of the taps is - and has always been - good.
What could be causing the burner to only fire with the hot taps wide open ?
