Hi there. I'm planning on putting some cleaner in my CH system. I have never done this before. I have a gravity fed system. boiler downstairs in garage, water tank in bathroom upstairs and then a small tank and larger tank in the lost. Is it a case of draining the system and then adding the cleaner to one of the tanks in the loft.
Also if this is the case, will I not be bathing in the water the cleaner is in. I thought the tanks up the loft were expansion tanks where the water tank calls water from as it's used. Bit confused. If anyone could give me some pointers that would be a great help
